Old 10-04-2011, 12:13 AM
sleiN13 sleiN13 is offline
That worked nicely. Still have a little bit of light corners on the leafs but atleast it looks like a actual tree now.
Old 10-04-2011, 08:45 AM
I forgot to mention, you should also disable blending when using alpha to coverage. This might fix the issue with the corners:
model.disable(viz.BLEND)
how to hide 3D virtual object behind real object? Darkmax Vizard 3 05-29-2012 09:39 AM
Remove link and have object drop/collide? cgibb Vizard 6 03-02-2010 04:18 PM
