Old 08-11-2011, 02:16 AM
osg Sequence
Im loading an ive file with an osg sequence that i would like to control.
Whats the best way of doing this?
I would like to be able to stop, start and set the current time of the sequence.
TarkaDahl
Old 08-17-2011, 10:20 AM
There's currently no built-in support for this, but we will add it to a future release.
If you are familiar with C++ programming and OpenSceneGraph, you could write a Vizard extension that does this. Our SDK is freely available and contains an example for writing an extension that interacts with the underlying scene graph of a node.
Old 08-31-2011, 07:42 AM
Hi
Im having a problem with this ive been looking at the example of creating an modifier using the sdk but how do a get from the osg::Node to the osg::sequence
ive looked at the documentation here.
http://www.openscenegraph.org/docume...cs/a00654.html
and it explains functions that i need to call on the osg sequence but i cant find how to get to the osg::sequence
Sorry it that doesnt make sence. but ive not used c++ for a while and have only done the basics of OpenSceneGraph.
I will do more reading about it later but any help would be good.
TarkaDahl
Old 08-31-2011, 10:11 AM
Support for controlling osg::Sequence nodes is in the latest version of Vizard (4.02). Here is some sample code:
model = viz.add('sequence.ive',pos=(0,1.5,4))
osg = viz.add('SceneGraphTools.dle')
sequence = osg.Sequence(model)
vizact.onkeydown(' ',sequence.setMode,vizact.choice([sequence.PAUSE,sequence.RESUME]))
vizact.onkeydown('r',sequence.setMode,sequence.START)
vizact.onkeydown('1',sequence.setFrame,50)
And here is the help print out of the sequence control class:
class Sequence(object)
 |  Methods defined here:
 |  __init__(self, node, name='')
 |  getBegin(self)
 |      Get the begin frame
 |  getClearOnStop(self)
 |      Get whether to show no children after stopping
 |  getEnd(self)
 |      Get the end frame
 |  getFrame(self)
 |      Get the current frame
 |  getFrameCount(self)
 |      Get the number fo frames
 |  getFrameTime(self, frame)
 |      Get the time for the specified frame
 |  getLoopMode(self)
 |      Get the sequence loop mode
 |  getMode(self)
 |      Get the sequence mode
 |  getNumRepeats(self)
 |      Get the number of repeat times
 |  getSpeed(self)
 |      Get the sequence speed
 |  getSync(self)
 |      Get whether to sync frames with frame time
 |  iterFrameTimes(self)
 |      Returns iterator that yields frame time values
 |  setBegin(self, begin)
 |      Set the begin frame
 |  setClearOnStop(self, clearOnStop)
 |      Set whether to show no children after stopping
 |  setEnd(self, end)
 |      Set the end frame
 |  setFrame(self, frame)
 |      Set the current frame
 |  setLoopMode(self, mode)
 |      Set the sequence loop mode
 |  setMode(self, mode)
 |      Set the sequence mode
 |  setNumRepeats(self, repeats)
 |      Set the number of times to repeat
 |  setSpeed(self, speed)
 |      Set the sequence speed
 |  setSync(self, sync)
 |      Set whether to sync frames with frame time
Old 09-01-2011, 02:45 AM
hi farshizzo,
Thanks for that it works like a dream.
how to freeze sequence of actions dwaik Vizard 1 04-05-2010 02:26 PM
How to make character animation sequence wchoi Vizard 3 01-22-2010 09:35 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
stopping a sequence durf Vizard 1 04-14-2009 02:31 PM
animation sequence pkhoosh Vizard 2 01-23-2006 09:03 AM
