You could use particle effects. Some samples can be found in this thread. You would need to modify one of the osg files there to get the water effect.
We have a precipitation plug-in documented in the Vizard Help that creates rain and snow effects. It's possible that could work for your application. You won't be able to specify a certain location for the water drops as they will fall throughout the entire scene. This may not be an issue if the view is from within the shower. |
| Tags |
| modeling, shower, water |
| Thread Tools | |
| Water rendering... help! | k_iwan | Vizard | 13 | 04-04-2014 11:57 AM |
| Vizard water surface and fabrics? | Darkmax | Vizard | 1 | 04-13-2010 03:39 PM |
| dlr water surface | Dave | Vizard | 3 | 07-17-2009 09:05 AM |
| VizWorkshop Article: 3D Modeling Software for Vizard Compared | Gladsomebeast | Vizard | 0 | 04-28-2009 11:43 AM |
| 3d modeling question | VDong | Vizard | 2 | 04-23-2009 11:40 AM |
