Old 06-24-2011, 03:49 PM
kevin kevin is offline
nVis SX/111 Display
Hi all,
The lab I work in has run into a problem with the display of the nVis SX/111 visor. The framerate seems to be rather low, or perhaps some frames are skipped. When turning the head (tracking being done by Intersense) there is significant jitter in the image as it updates at a rate that I would estimate to be around 20 hz. This problem is only present in the HMD itself. Monitors set up to also display left and right eye images are running smoothly.
I briefly tried using the nvis.nvisorSX() command instead of nvisorSX111(), and despite the display being rather distorted, it ran much smoother in the visor. Any suggestions as to what might be causing the problem?
display mode change, getting framerate dcnieho Vizard 3 05-23-2011 08:32 PM
Stereo HUD and Nvis SX111 kopper Vizard 5 10-29-2010 08:05 AM
Support for Philips IC3D Autostereoscopic display mspusch Vizard 0 07-13-2006 05:14 PM
Text Display bstankie Vizard 1 12-22-2003 04:23 PM
