Old 06-14-2011, 07:31 AM
kevin kevin is offline
The drift still happens. I've actually found that the car itself still navigates properly (we had switched to using an empty node). It's only the MainView which 'drifts.' The preMultLinkable operator seems to be the cause.
Old 06-14-2011, 11:43 AM
If I run the code I posted which uses a keyboard tracker to move the view I don't notice any drift. Is that what you are testing with or are you modifying the code at all or using a different type of tracker?
Old 06-14-2011, 12:53 PM
We're using an Intersense tracker. Perhaps the drift is occurring because the tracker is not centered to begin with?
I've managed to get things working properly by establishing a link between the tracker and the MainView and then using setPos and setEuler operators, directly calculating where the MainView should be given the car's position and heading, and the data from the Intersense tracker.
How to create mini car driving by wiimote superantTTY Vizard 7 05-18-2010 05:18 AM
How to pause the Vizard simulation? 4711 Vizard 4 03-18-2010 04:45 PM
Particle simulation imperialkat Vizard 0 01-29-2010 12:01 PM
driving simulator paulpars Vizard 1 05-12-2006 11:46 AM
