Old 05-20-2011, 10:45 PM
dcnieho dcnieho is offline
Question display mode change, getting framerate
Dear All,
I want to force a display mode change and exit out when errors occur, however I am having some trouble with querying the framerate the program runs at (viz.window.getFrameRate() always returns 0). Is the below a good way to do it?
 # setup display mode
 viz.setDisplayMode(resolution[0], resolution[1], 32, refreshRate)
 viz.setMultiSample(multiSample)
 viz.go(mode)
 viz.window.setFullscreen()
 # check displayMode set succesfully
 if  viz.window.getFullscreenRectangle()[2] != resolution[0] or \
  viz.window.getFullscreenRectangle()[3] != resolution[1] or \
  viz.window.getFrameRate()     != refreshRate:
  print '\nRequested display mode: '+str(resolution[0])+'x'+str(resolution[1])+'@'+str(refreshRate)+', got: '+str(viz.window.getFullscreenRectangle()[2])+'x'+str(viz.window.getFullscreenRectangle()[3])+'@'+str(viz.window.getFrameRate())
  viz.quit()
  sys.exit(-1)
In a related note, if I put in some ridiculous displaymode settings, Vizard always nicely gives me '** ERROR: Failed to set requested display mode', highlighted in red. Is there any way for me to get my own error messages highlighted in red (the print in the above code could use it)?
Thank you very much!
Best,
Dee
Old 05-20-2011, 11:24 PM
To answer this part of my question, I just came across viz.logError(), nice!
Best,
Dee
Old 05-23-2011, 09:59 AM
The following code shows how to retrieve the refresh rate of the monitor:
refresh_rate = viz.getOption('viz.monitor.refresh_rate',type=int)
Old 05-23-2011, 08:32 PM
Ah thanks, that works!
I did try viz.getOption('viz.display.frequency',type=int) before, but that doesn't work as it simply reports the frequency you asked for (however ridiculous), not the current refresh rate... viz.getOption('viz.monitor.refresh_rate',type=int) does exactly what I hoped for.
Change Viewpoint in different scenes lilio Vizard 1 08-28-2009 03:56 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
Support for Philips IC3D Autostereoscopic display mspusch Vizard 0 07-13-2006 05:14 PM
Text Display bstankie Vizard 1 12-22-2003 04:23 PM
