Old 05-17-2011, 07:18 AM
jaclyn.bill jaclyn.bill is offline
texture .ive or .wrl
Dear all,
I'm trying to wrap a checkerboard texture round a spherical object. I've tried using the default ball.wrl and a soccerball.ive
check = viz.add('checker.jpg',wrap=viz.REPEAT)
ball = viz.add('ball.wrl')
#ball = viz.add('soccerball.ive')
ball.texture(check)
ball.texmat( viz.Matrix.scale(1,1,10) )
This does not work at all with the soccer ball, which I'd have preferred as it's more spherical. It does work with the .wrl object but the checker board is normal on some surfaces and stretched on others - regardless of how much I play with the repeats and scales.
I essentially want it to look like a 3D version of the attached .bmp. Is my only option to draw one myself with many small black and white vertices?
Many thanks. Jac
Old 05-17-2011, 02:38 PM
Do you have 3ds Max or other modeling software?
Old 05-18-2011, 01:04 AM
No, unfortunately not
I could down load the 30 day trial of 3Dmax - if that version can do what you might suggest. But my research doesn't really warrent buying a full version so don't think that would be possible.
Thank you. Jac
Old 05-18-2011, 11:45 AM
Here's a checkerBall model you can use.
Old 05-19-2011, 01:57 AM
Thanks Jeff, really appreciate you sharing this with me.
unfortunately, I'm having trouble with it and get the following error
Warning: Could not find plugin to read objects from file "CheckerBall.IVE".
** ERROR: Failed to load 'CheckerBall.IVE'
I'm using version 3.18.0002. I have gone into my system properties - environmental variable and deleted references to a vizard 2.5 bin (as per a post on here) but this hasn't solved the problem. Do I need to update vizard itself?
I'm also running this on the Lite addition of Vizard and can't try it on the full version until next week, is that the issue?
Many thanks, Jac
Old 05-19-2011, 01:14 PM
Sorry, that will only work with Vizard 4, it was exported using the Vizard 4 OSG exporter. You can test it out now using the Vizard 4 Beta.
I'll post a Vizard 3 version as well.
Old 05-19-2011, 02:49 PM
This will work in Vizard 3.
Old 05-20-2011, 08:19 AM
Great, all working. Thank you very much!
Best, Jac
Weird texture on .ive model viewed from Sensics HMD Zhi Vizard 11 02-25-2013 04:38 AM
texture problem with .wrl file whj Vizard 5 05-01-2008 02:09 PM
