also i forgot to mention that i'm using vray to render the images
Are you using the S3TC Texture compression? If it’s set to IMAGE_DATE_FORMAT, the size will be bigger, but it wont have any compression. S3TC_ DXT5_COMPRESSION compresses and maintains the texture quality best.
What are the UV coordinates like? Maybe not enough room is allocated to receive textures. If that’s the case, it might also serve to break up the object to receive more texture sheets. |
| Thread Tools | |
| Getting data from a render texture | Joran | Vizard | 3 | 06-03-2013 03:11 AM |
| How to render a texture of the transparent object and then blur it | whj | Vizard | 1 | 09-25-2012 04:15 PM |
| black lines with render to texture | Darkmax | Vizard | 5 | 03-07-2011 12:23 PM |
| How to apply shader and render texture to an object | whj | Vizard | 0 | 04-23-2010 01:23 PM |
| Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 12:13 PM |
