Old 04-07-2011, 04:58 PM
Darkmax Darkmax is offline
opencv with vizard 4
Now that vizard 4 use python 2.7, some one had tried to use vizard with opencv?, i tried to install but i can't get it work.
I would like run opencv with vizard for a project that i had.
Old 04-09-2011, 01:02 AM
some one?? i check on the forum for open cv but is for 1.0 version, and i would like for 2.1 i some know how to use vizard with open cv 2.1
Old 04-10-2011, 10:33 AM
Ok, i'm experiment with opencv and this what i got:
1) I installed OpenCV-2.2.0-win32-vs2010.exe from the opecv site and i choose to install the system variables for all users.
2) I installed numpy-1.5.1-win32-superpack-python2.7.exe (because it seems that opecv need it)
3) I copy the files of C:\OpenCV2.2\Python2.7\Lib\site-packages to C:\Program Files (x86)\WorldViz\Vizard4\bin\lib\site-packages
4) i tried this code in vizard and it WORKS!!!:
import cv
cv.NamedWindow("camera", 1)
capture = cv.CaptureFromCAM(0)
while True:
    img = cv.QueryFrame(capture)
    cv.ShowImage("camera", img)
    if cv.WaitKey(10) == 27:
        break
cv.DestroyWindow("camera")
The problem is that when i tried this with another code like this one:
import Image
import cv
def PIL_TO_VIZARD(image,texture):
    """Copy the PIL image to the Vizard texture"""
    im = image.transpose(Image.FLIP_TOP_BOTTOM)
    texture.setImageData(im.convert('RGB').tostring(),im.size)
capture = cv.CaptureFromCAM(-1)#conectate a camara
tex = viz.addBlankTexture([1,1])
quad = viz.addTexQuad(pos=(0,1.8,2),texture = tex)
while True:
    src = cv.QueryFrame(capture)
    dst = cv.CreateImage(cv.GetSize(src),cv.IPL_DEPTH_8U,1)
    cv.CvtColor( src, dst, cv.CV_RGB2GRAY)
    #Convierto opencv to PIL image
    pil = Image.fromstring("L", cv.GetSize(dst), dst.tostring())
    #Aply image to texture
    PIL_TO_VIZARD(pil,tex)
        break
When i run this code it consumes me a lot of ram and then it freeze the machine
If anyone has a clue of what maybe is happening
Old 04-11-2011, 03:54 AM
nige777 nige777 is offline
Hi DarkMax,
Just wondering if you had any luck with this? All I get when is a black screen in the cvWindow instead of the stream from the webcam, most other samples from OpenCV seem to work although I haven't tried them all.
This would be a total game changer for me if Viz 4 and OpenCV can be made to play well together . . . . . . .
Old 04-12-2011, 06:15 AM
not yet, i'm still looking
Old 04-22-2011, 01:13 PM
Some that know why i can pass the image from the camera to a plane in vizard?
Old 05-11-2011, 11:20 AM
I resolve the problem, now i have opencv and vizard working together, just i have to use the viztask.schedule() command on the method that i use for opencv
Old 05-12-2011, 02:35 AM
Hi Darkmax,
Thats fantastic news, I'm still struggling to get openov to play nicely with Vizard, am even thinking of trying with pyopencv when I get a chance (writing writing writing at the moment ).
However, would it be possible for you to give me some advise as to how you have managed to get them working with each other, just a few pointers to get me started - I can use opencv with the highgui window, but am getting stuck trying to pass the video frames to the vizard render window .
Any advise would be really welcome,
best regards
Old 05-13-2011, 06:14 AM
try this code:
import Image
import cv
import viztask
#Quad to display the image on vizard
def opencvMain():
	capture = cv.CaptureFromCAM(-1)#conect to a camera
	while True:
		src = cv.QueryFrame(capture) #Image from camera in BGR format
		dst = cv.CreateImage(cv.GetSize(src),cv.IPL_DEPTH_8U,3)
		cv.CvtColor( src, dst, cv.CV_BGR2RGB) #Converting BGR to RGB
		#Converting opencv image to PIL image
		pil = Image.fromstring("RGB", cv.GetSize(dst), dst.tostring())
		cv.WaitKey(10)
		yield viztask.waitTime(0)
viztask.schedule(opencvMain())
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 03:14 PM
