Old 05-11-2011, 07:10 AM
Zhi Zhi is offline
Hi Tobin,
I used the DXT1 compression. Now the problem solved (See attached screen-shot). Great! Thank you for your suggestion.
By the way, what is the difference between the different compression modes. How does user know which mode to use?
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 04:28 PM
