Old 05-10-2011, 10:54 PM
tobin tobin is offline
First, can you confirm that you still don’t get this artifact with other 3D software in conjunction with your triphead2go device? It seems to be an interaction between the triplehead2go drivers, your display drivers, and possibly Vizard. This will be difficult to replicate without the exact same hardware.
Second, it’s a bit of a shot in the dark, but have you tried exporting the IVE with DXT1 compression?
Re opening a support issue, you may go ahead and upload your MAX file to the dropbox below and we’ll have a look to see if there’s anything particularly unusual with it:
http://www.worldviz.com/support/upload.html
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 05:28 PM
