Old 04-26-2011, 06:47 PM
SteveEB SteveEB is offline
Vizard Interface with CAVE System (LINKING)
Hi all,
The lab I am working in uses Vizard hooked up to a CAVE (Mechdyne) system. The problem I'm occurring has to do with linking to an infra-red tracker.
I set up a link between the lower arms of the human female.cfg and the tracker in order to have the arms follow the tracker as they are moved about in the environment. The arms move with the trackers on the desktop that is running Vizard, however there is no change in the avatar displayed on the CAVE projector. This is the first time that we have encountered difficulty in interfacing the two systems, so any help would be greatly appreciated.
Old 04-27-2011, 01:22 PM
Do you have a master that displays to a desktop and clients that render the walls?
If the avatar only moves on the master it could be that code is placed within a cluster mask.
Old 04-29-2011, 09:26 AM
Unless masks are turned on by default, we currently are not using any masks.
Old 04-29-2011, 12:09 PM
Can you post some code that replicates the issue for you?
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
running Vizard on a two-wall CAVE nitao Vizard 1 12-16-2009 01:48 PM
right-hand to left-hand coordinate System for a cave setup Andy Vizard 1 09-16-2009 11:17 AM
Problems implementing Vizard in a CAVE with Shutter Glasses shivanangel Vizard 7 05-20-2009 12:47 PM
