Old 04-25-2011, 04:15 PM
Zhi Zhi is offline
Weird texture on .ive model viewed from Sensics HMD
Hi all,
I am using Vizard 4 beta2. I have a Sensics xSight HMD with 6 panels on each eye. I export a 3D building model from 3ds max 9.0 to a .ive file. The model contains materials with textures. It looks fine in the 3ds max. It also looks fine if it is shown on the LCD monitor (as with viz.go() command). The problem is when I looked through the xSight HMD the texture looks really weird (see attached screen-shot, left).
The Sensics has a plug-in for Vizard, which is convenient for user to setup the HMD. Only needs two line codes:
import sensics
hmd=sensics.load(panelalign="panelalign.txt",layou t="layout.txt",clearcolor=viz.BLACK)
The layout.txt file contains information where to output the images. If I output the images to the HMD (via two TripleHead2Go splitters), the images look weird as I shown above. However, if I output the images to a LCD monitor, it looks just fine (see attached screen-shot, right).
Does anyone has any idea why this happens? Is it a problem of Vizard or is it a problem with Sensics plug-in.
Thanks in advance.
Name:	From headset.JPG
ID:	421   Click image for larger version
Name:	On monitor.JPG
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 04:28 PM
