Try using the <texture>.anisotropy or <node>.anisotropy commands. Anisotropic filtering is used to alleviate the exact problem you are having.
If that doesn't help, then you might need to use a higher resolution image. |
| Thread Tools | |
| Jpeg Image issue? | VelvetElvis | Vizard | 0 | 03-05-2010 06:20 AM |
| Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
| screen image | erchrastil | Vizard | 8 | 06-27-2008 11:45 AM |
| View an image on the Fakespace HMD | roman_suvorov | Vizard | 16 | 05-23-2008 07:51 AM |
| Only part of tiled image | vizmaster | Vizard | 5 | 09-11-2006 12:11 PM |
