Old 04-06-2011, 04:24 AM
dorijan dorijan is offline
vrpn and viz.MainView.setPosition not working
Hi to all...
I managed to get working my tracker(VR Space) with worldviz, but I did not managed to set viewpoint where I want it to be. Problem is that I set viewpoint with viz.MainView.setPosition where I want it to be, but when I link it to my tracker with viz.link(tracker1,viz.MainView) it is lost somewhere
I tried with tracker1.swapPos, viz.MainView.move but the tracker is always in the same position.
p.s. I do not want to use tracker to move viewpoint, I just want to rotate...
thank you...
Old 04-07-2011, 12:35 PM
so, is there any way to fix viewpoint? I really need a quick fix
Old 04-07-2011, 12:40 PM
You posted the question in the wrong forum. This should be in the Vizard forum.
Regarding your question, just change the link mask between the tracker and viewpoint to only control the rotation:
viz.link(tracker1,viz.MainView,mask=viz.LINK_ORI)
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
VRPN or trackd with OptiTrack RigidBody vizmaster Vizard 1 08-13-2008 12:11 PM
swapPos and swapQuat with VRPN michaelrepucci Vizard 1 07-29-2008 11:27 AM
VRPN won't update Wytze Precision Position Tracker (PPT) 7 05-28-2008 07:15 AM
