Old 02-10-2011, 09:11 AM
How are you creating the cone/cylinder objects? Are you using the vizshape module?
I just tried it out, and the cylinder object created by the vizshape module is affected by light.
If you could provide some sample code, that might help us debug your issue.
Old 02-11-2011, 08:26 AM
renama renama is offline
We use on-the-fly object by using viz.startlayer(), viz.endlayer(). I did not know the vizshape module. That works better. Thank you!
lighting issue cantwelljm Vizard 3 02-18-2006 08:21 AM
The effect of lighting on performance JRichizzle Vizard 1 06-18-2004 10:40 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
Lighting Problem Plasma Vizard 1 02-03-2004 11:09 AM
Vizard 2.0x lighting FlyingWren Vizard 4 08-11-2003 12:20 PM
