Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 01-10-2011, 08:22 AM
hengshan.li hengshan.li is offline
Hi, Jeff, Thanks very much for your reply.
I export using the the units as it is illustrated. However, the model still can not be navigated. And the code in Vizard is very simple just as below:
room=viz.add('C:\\Users\\Hengshan\\Desktop\\3d max model\\for vizard\\test1.IVE')
I uploaded the 3ds file:
http://www.adrive.com/public/dca76db...8831b6c92.html
Thanks very much!
Hengshan
Old 01-10-2011, 12:07 PM
Hi Hengshan,
Regarding baked textures not showing up in Vizard, make sure the map is being output to the diffuse of a Standard material. For additonal information, refer to this knowledge base article:
http://kb.worldviz.com/articles/1393#more-1393
I also took a look at your file. You have a scale issue. All models in Max are stored in generic units, unrelated to any real-world scale. The "System Unit Scale" setting tells Max how to translate its internal units to real world sizes. This is why changing the system unit does not acutally rescale anything.
Create a box, and type in the values to make it 1 meter high, and you will see the problem.
To fix the scene, use the Rescale World Units utility. It will ask for a scale factor. This depends on what the System Unit Scale was originally set to. The simplest way to get the correct scale factor is to use Google. Searching for "inches to meters" will give the result "1 inches = 0.0254 meters", for example.
Vizard and OBJ Material Files shivanangel Vizard 3 10-04-2013 06:11 AM
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 03:14 PM
