Old 12-23-2010, 07:38 PM
psykoko psykoko is offline
Hi. i did modify my code, but i don't work correctly.
please modify my code
import vizmat
import vizinfo
import socket
import struct
#Add an avatar to the scene
female = viz.add('vcc_female.cfg')
viz.clearcolor(0.5,0.5,1)
female.setPosition([-0.08,0,0.8])
female.setEuler([0,0,0])
female.scale(1.4,1,1)
#Get a handle to the Arm bone
Forearm = female.getBone('Bip01 R Forearm')
Forearm.lock()
Forearm.setEuler(0, -5, 0)
UpperArm = female.getBone('Bip01 R UpperArm')
UpperArm.lock()
UpperArm.setEuler(0, -30, -80)
Hand = female.getBone('Bip01 R Hand')
Hand.lock()
Head = female.getBone('Bip01 Head')
Head.lock()
Head.setPosition(-100,0,0)
Neck = female.getBone('Bip01 Neck')
Neck.lock()
Neck.setEuler(0,0,-15)
UDP_IP="localhost"
UDP_PORT=8000
sock = socket.socket( socket.AF_INET, # Internet
					socket.SOCK_DGRAM ) # UDP
sock.bind( (UDP_IP,UDP_PORT) )
udp = 0
def example1():
	global udp
	while True:
		data, addr = sock.recvfrom( 1024 ) # buffer size is 1024 bytes
		udp = struct.unpack(">d", data)[0]
	True.close()
viz.director(example1)
def update():
	print udp
	right = open('c:\\ownership\\test4.txt', 'a+')
	right.write(str(udp)+'\n')
	if 0 < udp:
		a = Forearm.getEuler()
		A = a[2]
		n = max(A -0.5,-90)
		N = A + 90
		Forearm.setEuler(0,0,n)
		if n == -90:
			Forearm.setEuler([0,0,N])
	else :
		b = Forearm.getEuler()
		B = b[2]
		n2 = min(B +0.2,0)
		Forearm.setEuler(0,0,n2)
vizact.ontimer(0,update)
Old 12-28-2010, 01:52 AM
Hi. worldviz.
is this not solved my problem??
i want to your help.
i don't solved my problem
Old 01-02-2011, 01:18 PM
What's not working?
Loading OSG models and orientation Joran Vizard 4 06-18-2009 05:43 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 04:44 PM
Script loading problem JRichizzle Vizard 1 03-12-2004 10:03 AM
