Old 11-22-2010, 11:30 AM
Hi sleiN13,
OSG Occluders are found under Helpers in the Create tab of the command panel. Select OpenSceneGraph from the dropdown list and the option should appear.
Doing occluders in OSG requires two things:
-The helper
-Rectangular splines that get added to the helper
Old 11-23-2010, 08:27 AM
sleiN13 sleiN13 is offline
That works very nicely thanks you
Never thought off looking in that create menu always assumed the same things would be in me create menu in the main menubar.
Invisible haptic objects Haptiken Vizard 1 05-05-2009 05:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
