Old 11-02-2010, 03:22 PM
Kaminski Kaminski is offline
program is freezing
Hi all,
I am having a strange error with a script and am stumped as to what is happening. Any advice would be appreciated.
I am running a Vizard script that communicates through a serial port with an fMRI scanner and a button box. I have run the program 6 times, and 3 of those times the graphics froze. There are no runtime errors and Vizard doesn't detect (or output) button presses. It seems to happen completely randomly, except always at the same spot of a looping trial. I am running Vizard 3.0 on a Windows XP machine. I realize that it is hard to help without seeing the code but I was wondering if anyone has had any similar issues?
thanks,
-B
Old 11-02-2010, 03:33 PM
Also I have made sure that the virus scan is disabled as well as the screen saver/sleep mode.
Old 11-04-2010, 12:24 PM
How are you getting the serial data? Try using a director function, which will run in a separate thread, to read in that data.
How can i import the code form a Java program to Vizard? alberto_redo Vizard 1 10-07-2010 01:18 PM
How do I run a destructor before the end of the program? EnvisMJ Vizard 3 12-14-2009 06:17 PM
changing the gain of a joystick during a program Saz Vizard 4 06-25-2009 04:49 AM
Get position data in an own little program Researcher Precision Position Tracker (PPT) 2 02-01-2006 03:55 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 05:44 PM
