Old 01-21-2005, 01:18 PM
oscar oscar is offline
Help
HI,
I`m trying to move a simple ball after that I`ll change the size of the object, But I need that this two events happen one by one, not the both at the same time.
Can Any body help me ?
Old 01-21-2005, 01:25 PM
Do you want to animate the ball moving and then animate it changing size?
Old 01-21-2005, 01:42 PM
I`ll like to animate the ball with tha goto function, and when the ball finish, chage the size of it.
Old 01-21-2005, 02:35 PM
If you have vizard 2.5 you could do something similar to the following:
move = vizact.goto(0,0,5,1)
changeSize = vizact.scale_node(3,3,3)
ball.add(move)
ball.add(changeSize)
If you have an earlier version of vizard then you would have to use callbacks:
def ballStop(object,type):
	if type == viz.MOVE:
		ball.scale(3,3,3)
ball.callback(viz.STOP_EVENT,ballStop)
ball.goto(0,0,5,1)
