Old 09-27-2010, 12:14 PM
The second dialog in the publish wizard contains a checkbox labelled Display console. You can use this option to display an output console for your published exe.
If you prefer to log the ouput to a file, then you can use the viz.setLogFile command to redirect all output to a file. You will probably want to specify an absolute path if using this command with a published exe.
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Which software can be used to edit .cfg (CAL3D) files luakt Vizard 4 09-12-2008 08:18 AM
Writing text files with executable adimov Vizard 1 03-21-2008 04:21 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
