Old 09-16-2010, 11:54 AM
You're getting that error in the first piece of code because the viewpoint is being placed in a location that causes a collision when the collision event occurs.
In the second piece of code the viewpoint is set to [0,1.82,0] unless the eyeheight has been changed. That command will always move the view above the origin.
If you want to move the viewpoint somewhere else use
viz.MainView.setPosition()
but make sure the position is not at ground level or colliding with another object.
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
How can you dynamically change the gain on a tracker-based CaveView? michaelrepucci Vizard 2 09-23-2008 07:18 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
