Old 09-10-2010, 08:48 AM
tsgk tsgk is offline
Post How to add texture to a polygon
I am trying to create a textured on-the-fly polygon but have not much luck yet.
The polygon I am using has the following vertices:
viz.startLayer(viz.POLYGON)
	viz.vertex(x+(1.5), 0.02, 0)
	viz.vertex(x+(1.5), 0.02, straight_road)
        i = 0
	while i < 3142:
		x2[i] = (r-(1.5))*cos(right_array[i])
		z2[i] = (r-(1.5))*sin(right_array[i])
		viz.vertex(x2[i]+r, 0.02, z2[i]+9)
		i += 1
	viz.vertex(r-(1.5), 0.02, 9)
	viz.vertex(r-(1.5), 0.02, 0)
	myPolygon = viz.endLayer()
The while loop is used to generate a semi-circular side to the polygon.
I am not sure how to apply the
viz.texcoord
command since at the best with four [x,y] coordinates I can draw a square.
Is there a way of adding a .jpg or .bmp file as a texture in this kind of shape? What I intend of using is a seamless texture image that will repeat itself, so the orientation will not be important.
Any help will be greatly appreciated!!
George
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
Translating a texture and its Alpha shivanangel Vizard 5 12-02-2008 05:52 PM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 01:12 PM
