Old 09-09-2010, 07:04 PM
The extension .ive is the compiled form of the OSG format. We have an OSG exporter for Max available on our downloads page.
The easiest way to control the animation of spinning wheels would be to use the method described in the tutorial above.
Otherwise, you could create the animation in Max and export to OSG format. To play/stop it in Vizard you would need to use the module provided in the following thread:
http://forum.worldviz.com/showthread.php?t=2709
After a using speak, model returns to idle animation? Enlil Vizard 4 08-06-2010 01:42 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 06:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 03:11 PM
avatar animation problems jrodman Vizard 1 01-18-2006 10:12 AM
