Old 07-28-2010, 12:11 PM
mspusch mspusch is offline
In Vizard, go to Help -- > Check for Updates. Is your version up to date? If not, download and install the most recent version. Do you still get an error when you run the following?
isense = viz.add('intersense.dle')
Old 07-28-2010, 12:30 PM
znchb znchb is offline
# I just tried and get this work well: orientation & position for one of those 4 # sensers. (try to link View with just one Sensor, each try works.)
# Now I'm trying to use sensor 1 to control orientation& position
# and using sensor 2 to replace mouse
# sensor 3 & 4 replace left hand and right hand
# for sensor 2,3,4, could you give me any idea ? thanks
import viztracker
viz.clearcolor(viz.BLUE)
#tracker = sensor.addTracker()###error
#viz.tracker()
PORT_INTERSENSE = 1
sensor1 = viz.add('intersense.dls')
PORT_INTERSENSE = 2
sensor2 = viz.add('intersense.dls')
PORT_INTERSENSE = 3
sensor3 = viz.add('intersense.dls')
PORT_INTERSENSE = 4
sensor4 = viz.add('intersense.dls')
# link which sensor, which sensor will
# control the view orientation and walk position
S = sensor1
link = viz.link( S, view )#link the senser to view: perform orientation and #position with head tracker
def ontimer(num):
#the original pos and euler are [0.0, 0.0, 0.0]
pos = S.getPosition()
euler = S.getEuler()
print pos
print euler
viz.MainView.setPosition(pos[0]*10,pos[1]+1.82,pos[2]*10)
viz.MainView.setEuler(euler[0],euler[1],euler[2])
viz.callback(viz.TIMER_EVENT, ontimer)
viz.starttimer(0, 0.01, viz.FOREVER)
Old 07-30-2010, 01:10 PM
Please post code using the code tags to preserve indentaton.
Are you saying that if you replace the line
S = sensor1
with a different sensor number the link works with the new sensor and the viewpoint? If that is the case then you just need to create four links for the four sensors. Updating the viewpoint position and orientation in the timer function is not necessary if you created a link between the two.
I'm not sure what you mean by using sensor 2 to replace the mouse.
Besides tracking the hands to you also have glove data for them? Either way you can add left and right hand models that are linked to the tracking data.
Old 08-02-2010, 02:48 PM
Actually, I need to use four viz.link,
(1) link(Intersense HeadTracker, ViewPoint)
(2) link(Intersense Wand, mouse)
(3) link(Intersense HandTracker, Data Glove)
(4) link(Intersense HandTracker, Another Data Glove)
also, the Data Glove is plug in by viz.add('5dt.dls')
I want to gain the performance as the following picture I draw.
\ Glove /
\ view /
the glove locates before our view, and if view move and hand move, the glove will also move.
after linking, the position of data glove is far away from viewpoint, even I put the headTracker & Handtracker together.
I think it's the problem of controlling positions of device. Is that right ?
Old 12-06-2010, 09:12 AM
blessonisaac blessonisaac is offline
Can u help me with this?
I tried to connect Head tracker and Wand at the same time
But my wand does not work. My script is wrong link=viz.link( T,mouse). Can u tell me
the correct script?
import viztracker
viz.go(viz.QUAD_BUFFER)
PORT_INTERSENSE = 1
PORT_INTERSENSE = 2
S = sensor1
T = sensor2
link=viz.link( S,view)
viz.collision(viz.ON)
Old 12-06-2010, 09:13 AM
Two Intersenses
the correct script?
import viztracker
PORT_INTERSENSE = 1
PORT_INTERSENSE = 2
S = sensor1
T = sensor2
