Old 07-21-2010, 08:48 AM
llqqff llqqff is offline
Cyberglove left hand not able to connect
Hi, I am using cyberglove with vizard, then when the right glove is connected, I can use the following code to connect to the glove
immersion = viz.add('immersion.dle')
glove = immersion.addCyberGlove()
But when using the left glove, I am not able to connect to the glove, the message shows:
** ERROR: Failed to connect to CyberGlove. Make sure Device Manager is running.
Could not connect to device.
** ERROR: Failed to create extension sensor with immersion.dle
So is there any difference connecting right glove from left glove?
Thanks.
Old 07-21-2010, 11:18 AM
What is the virtual COM port assigned to the left glove? You can check that in the device manager. Try specifying the port when you add the Cyberglove and see if that works.
Old 07-21-2010, 11:47 AM
Thanks, Jeff. Problem solved!!
Connecting cyberglove with character llqqff Vizard 1 04-26-2010 11:30 AM
Head tracking, Flock of Birds and vizcave; how do I connect them? Arandia Vizard 2 08-26-2009 04:59 PM
Immersion Cyberglove connection problem gwfassociates Vizard 1 05-17-2009 03:29 PM
