Old 06-22-2010, 03:42 PM
EnvisMJ EnvisMJ is offline
Streaming Motion Capture
We would like to stream live motion capture data from our capture system into vizard to allow us to animate a character that we created (rigged with Max biped).
Is there a way to do this without MotionBuilder? We've had endless problems with MotionBuilder and would rather not use it in this pipeline if we don't have to.
Has anyone actually done this?
Old 06-22-2010, 03:47 PM
What motion capture system are you using? This is technically possible, it's just a very difficult and time consuming task. Without MotionBuilder, you will need to perform all the IK and motion targeting yourself.
If you feel you are up to the task, then have a look in the docs for manually controlling the bones of an avatar.
Old 06-22-2010, 03:54 PM
We're using a 6 camera STT Motion Captor system with SD cameras.
I would be really surprised if you've heard of it... it's kind of ...obscure...
Old 06-30-2010, 08:05 AM
VelvetElvis VelvetElvis is offline
You can actually skip motion builder all together. You can load the .bvh file or other motion capture format directly onto the biped in Max.
You can load all of your animations in one sequence or sequence them out and control which ones are loaded in what order in the cfg file in Vizard.
Granted, it would be much easier if Vizard supported animated bipeds directly (ie reading the .bip file and translating that onto the bones as it does in Max) or could read the point cache files (either in xml or pc2 format) created in Max, but that would be too simple.
Old 07-06-2010, 10:50 AM
Unfortunately, our MoCap format isn't directly 3DS Max compatible. Also, doesn't sound like a streaming operation?
Motion Capture & CyberGloves EnvisMJ Vizard 1 10-01-2009 04:21 PM
screen capture from all cluster computers? dtidrow Vizard 1 09-16-2009 10:25 AM
Motion Capture Props staircaseduets Vizard 1 07-09-2009 12:56 PM
Eliminate Sideways Motion when colliding w/Objects Feuereissen Vizard 3 07-09-2009 12:43 PM
Vizard Enterprise Edition and motion capture aaThomas Vizard 4 10-05-2007 10:31 AM
