Old 06-02-2010, 06:03 PM
nige777 nige777 is offline
Unhappy re: Calendar
Quick question about the standard python calendar module - seems it works great in the interactive input window, but when using it in a script - whatever function of calendar I try to use throws a
  File "calendar.py", line 2, in ?
    import calendar
  File "calendar.py", line 5, in ?
    print calendar.month(2010,6)
AttributeError: 'module' object has no attribute 'month'
- type of error - however confusingly (for me ) month, and its attributes was suggested by vizard & this exact same line will be happily accepted through the interactive window and prints out a calendar for June 2010? Am I missing something really silly here??
My code is VERY simple -
import calendar
Any help would be appreciated
Old 06-02-2010, 06:08 PM
You probably created a file called calendar.py in your script directory, which is overriding the built-in calendar module. Rename the file and it should work.
Old 06-03-2010, 04:13 AM
Red face re:
Ha ha, I knew it would be something really silly - working late at night again!!
Thanks farshi
