Old 01-12-2010, 01:58 PM
starbug starbug is offline
exiting a yield statement
Hello there,
I have a question regarding exiting a yield statement, after a certain time elapsed. I am changing a global variable according to a keypress (using yield viztask.waitKeyDown) within a function, if that keypress should not happen, I want to exit the yield statement after a certain time interval. And continue the protocol with the unchanged global variable.
I might be wrong using yield, and there is some other way (I read about python threading?Running a timer parallel to yield?), could you point me to some example code? I couldn't find this scenario in the tutorial.
Thank you.
Step=1
Motion = 15
def control():
	global Motion
	..... #dosomething with Motion
	for i in range(1,x)
		d = viz.Data()
		yield viztask.waitKeyDown(['y','n'],d) #or, if no key was pressed, after 2 sec exit yield
		if d.key == 'y':
			Motion = Motion - Step
		elif d.key == 'n':
			Motion = Motion + Step
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 05:30 PM
switch statement vrlab Vizard 1 08-04-2004 11:23 AM
