Old 09-27-2009, 12:14 PM
vTony vTony is offline
Setting Collidebox Dimensions
Hello, I am trying to manually set the dimensions of an object's collidebox. As a simple test, I tried setting the dimensions of the collidebox to the size of the object's bounding box. This works for box.wrl, but with the file tree.3ds (located at https://www.stanford.edu/~tony516/tree.3DS), I get strange results. The tree on the left (which uses the default arguments for collidebox, behaves normally, but the tree on the right shoots up into the air.
import viz, vizact
def setOnGround(obj):
ymin = obj.getBoundingBox().ymin
pos = obj.getPosition()
obj.setPosition(pos[0], pos[1]-ymin, pos[2])
def enablePhysics():
viz.phys.enable()
ground.collidePlane()
tree1.collidebox()
tree2.collidebox(tree2.getBoundingBox())
viz.clearcolor(viz.SKYBLUE)
viz.MainView.move(0,0,-15)
tree1 = viz.add('tree.3ds')
tree2 = viz.add('tree.3ds')
tree1.scale([.2]*3)
tree2.scale([.2]*3)
tree1.setPosition(-10, 0, 15)
tree2.setPosition(10, 0, 15)
setOnGround(tree1)
setOnGround(tree2)
vizact.onkeydown('1', enablePhysics)
Thanks in advance for any help!
Tiling in a cluster setting vijaykiran Vizard 5 10-30-2009 11:41 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
error while setting material properties. Chandan Vizard 1 10-25-2006 09:31 AM
Setting the viewpoint with tracking VAmanda Vizard 3 10-26-2005 02:02 PM
Setting up a 'reaction area' Karthi Vizard 4 01-29-2004 04:39 PM
