Old 01-27-2009, 05:37 PM
When you create the custom node object, you can optionally specify additional arguments:
mynode = viz.add('mynode.dlc',command,mesg,x,y,z,w)
You can also send additional commands to the node once it is created:
mynode.command(command,mesg,x,y,z,w)
The command, mesg, x, y, z, w values are part of the VizCustomNodeObj structure that is passed to your C++ function.
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Custom Render .EXE export vaestebob Plug-in development 2 05-12-2008 07:55 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
