Old 12-09-2008, 01:33 PM
need some help with projection (maybe via module projector.py)
Hi Vizards, there doesn't seem to be much help on the projector.py module, just a few examples. This would be enough if I were trying something typical, but, as usual, I'm not. I'm not even sure that I can use projector.py to do this, but here goes.
What I have is an on-the-fly object which is essentially a 2D checkerboard. I would like to position it at some arbitrary angle and point in space, and then project its image onto an invisible surface at some other arbitrary angle and point in space.
For instance, if the checkerboard were slanted by 45 degrees, then projected onto an invisible wall placed between it and the viewer, the viewer would see the same image (it would look like a slanted checkerboard), but the image on the wall would actually be an unslanted, foreshortened checkerboard.
Can I use projector.py to do this, and, if so, how? Or is there some other Vizard tool I can use to do this arbitrary projection? Or will I have to calculate the projection matrix myself and manually adjust all the vertices in the OTF object?
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
RE: Shadow Module nige777 Vizard 2 05-08-2008 05:52 PM
Viewing Projection pkhoosh Vizard 2 01-25-2006 10:52 AM
Fading/lightening-Problem and viz.go in module Johannes Vizard 6 09-02-2005 05:28 PM
vhil module vadrian Vizard 2 01-27-2005 12:52 PM
