I tracked down the problem to trying to override the texture inside the IVE file.
I already had the image applied with the alpha in MAX. When I went to reapply it in Vizard it did so to the texture but not the alpha. However, when I added a flat material with no texture I lost my UV coords of the object. To FIX everything, all I did was remove my alpha parameters inside of MAX and then exported to IVE. After that I applied my texture with the alpha and now the alpha moves with the texture. Thanks for the help, I couldn't of fixed this without the troubleshooting, George L. |
