Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 10-14-2008, 02:34 PM
TrashcanPatrol TrashcanPatrol is offline
Hi thank you for your response, I've tried what you said but it doesn't work still. Here is what I tried:
SAFE = 1
UNSAFE = 2
TARGET = 3
CIRCLE_X = -3.5
CIRCLE_Z = 3.4
CIRCLE_RADIUS = 0.5
def handlemyhotspots(id,x,y,z):
	if id == SAFE:
		print 'inside safe zone'
		def mykeyboard(key):
			if key == 'e':
			door.runAction( vizact.spinto(0,1,0, -90, 30.0) )
		viz.clearcolor(1,1,1)
		viz.starthotspot(UNSAFE,viz.RECTANGLE_HOTSPOT_OUT,0,3,2.4,6)
	elif id == UNSAFE:
		print 'outside safe zone'
		viz.clearcolor(0,0,0)
		viz.starthotspot(SAFE,viz.RECTANGLE_HOTSPOT_IN,0,3,2.4,6)
	elif id == TARGET:
		print 'at target'
viz.callback(viz.HOTSPOT_EVENT, handlemyhotspots)
viz.starthotspot(TARGET,viz.CIRCLE_HOTSPOT_IN,CIRCLE_X,CIRCLE_Z,CIRCLE_RADIUS)
import math
viz.startlayer(viz.LINES)
viz.linewidth(3)
viz.vertexcolor(viz.RED)
viz.vertex(CIRCLE_X,0,CIRCLE_Z)
viz.vertex(CIRCLE_X,2,CIRCLE_Z)
viz.startlayer(viz.LINE_LOOP)
for a in range(0,360,10):
	x = math.sin(viz.radians(a))*CIRCLE_RADIUS
	z = math.cos(viz.radians(a))*CIRCLE_RADIUS
	viz.vertex(x+CIRCLE_X,0.1,z+CIRCLE_Z)
viz.endlayer()
room=viz.add('room.wrl')
viz.collision(viz.ON)
door = room.getchild('door-FACES')
import vizcam
vizcam.FlyNavigate()
  if key == 'e' and id == SAFE:
--but it doesn't let me open the door like that though. The boldened part I know won't work [and it's not in my code that I was just using] but that's what I'm trying to do with it, it's hard to describe using two definitions with words though.
What do you think I should do for that?
