Old 11-21-2007, 10:22 AM
The center() command should not be moving the object. It simply sets the rotation pivot point. Are you sure you are setting the center to the correct location? Here is an example that uses the cone model that comes with Vizard.
#Setup environment
viz.add('tut_ground.wrl')
viz.clearcolor(viz.SKYBLUE)
viz.move(0,0,-20)
#Spin cone
cone = viz.add('tut_cone.wrl')
cone.addAction(vizact.spin(0,1,0,90))
Since the cone if offset 8 meters from the origin it will spin around the origin. Now add the following code to the script:
cone.center(0,0,8)
Now the center is placed at the cones location, so it will spin around its local origin.
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
getting absolute rotation tavaksai Vizard 1 08-03-2004 01:40 PM
