Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 09-19-2006, 07:10 AM
bnord bnord is offline
trouble with winviz.exe
I have some trouble with winviz.exe of V3b. After exiting the application via Escape button, there is still a process "winviz.exe" visible in the Task-Manager which has to be killed manually. This happens without any additional DLLs like Philips OGL Wrapper (not installed on this system). I think this could be in conjunction with a thread that is responsible for loading textures. Sometimes (after different times of running) an exception is thrown.
The Traceback looks like this:
File "C:\Programme\WorldViz\Vizard30\bin\lib\threading. py", line 442, in __bootstrap
self.run()
File "TextureLoaderThread.py", line 68, in run
if textureSet[slotToReplace] == None:
File "C:\Programme\WorldViz\Vizard30\python\viz.py" , line 1992, in __eq__
return self.id == other.id and isinstance(other,self.__base)
AttributeError: 'NoneType' object has no attribute 'id'
The code worked fine with 2.53. Is there a general change in Version 3 that could cause this?
Best regards,
Björn
