I believe this is related to a known bug in 2.53. If you specify a mesh name that is invalid then Vizard will use the first mesh file instead. This has been fixed in 3.0. In the meantime, make sure the mesh name you are specifying is correct. In your sample code you specify shirt.CMF but it is not in your mesh list. However there is a shirt.CRF in your material list. Are you sure you are not mixing up meshes with materials? |
