Old 10-26-2022, 02:39 PM
apenngrace apenngrace is offline
Modify tracker position before next frame
Is there a way to set the position of the "head" when vizconnect is running? If glasses are out of range, and the tracker value is 0,0,0, the frustrums of our CAVE displays are kind of off. I have to walk into the CAVE space and wave glasses around so that vizconnect gets a more reasonable tracker value.
When the glasses are out of range, I'd like to set a default head position value.
I'd like to be able to test for the tracker being near 0,0,0, and then provide a default head position higher up like (0.208, 1.682, -0.339). When I access the tracker with vizconnect.getTracker(), I see that there is a getPosition() method but no setPosition() method.
Is there some way to register a call-back or something to be able to review and modify the tracker position value before the next frame gets displayed?
help with mouse as tracker position bbb Vizard 4 11-16-2015 03:32 PM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
get tracker position and euler chris_user Vizard 2 07-01-2011 01:31 AM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 09:26 PM
