Old 01-09-2018, 10:27 AM
A Wundlechner A Wundlechner is offline
Check for running SteamVR
Hello everyone,
for my program I want to use 2 different controlling scemes. One should be controlled with a gamepad and the other one is for steamvr. I want the following behaviour:
If steamvr is already running, I want to use the steamvr controlles.
If it's not running, I want to use the gamepad.
For those 2 cases I've already created 2 configfiles with vizconnect and I changed my specific code parts within the scripts. I only need to know if steamvr is already open.
I haven't found a helpfull command within the steamvr library, to check if steamvr is running. If I run the steamvr.HMD() command when steamvr is closed, it just opens steamvr.
Thanks in advance,
Andreas Wundlechner
controller, steamvr, vizconnect
check if fixation is on target VizMars Vizard 1 11-14-2017 11:20 PM
how to check if specified number of targets are in proximity sensor? Vaquero Vizard 8 12-27-2016 06:23 PM
Check if file exists jassel41 Vizard 2 09-27-2011 12:22 PM
Check presence of joysticks ? hotspur1 Vizard 1 05-18-2010 11:33 AM
Check if an avatar has a state "123" Josh Vizard 1 04-06-2010 02:11 PM
