Old 05-08-2017, 11:33 AM
Vaquero Vaquero is offline
Hey raj!
A more realistic lighting model like you'd get with Unity or Unreal Engine 4, which both do this by utilizing physically based rendering, is not implemented in Vizard. But there's the possibility to write your own shader code. The support gave me this answer a while back:
»If you're using the effects framework you need to use the GLSL version released with OpenGL 2.0. If you write your shader from scratch then you can declare the GLSL version you want to use.«
So you see, it's a really old OpenGL implementation that Vizard uses and the shader code is outdated, which makes it hard to find helpful code reference on the internet.
I tried implementing some PBR shading, but didn't had the time to finish the project.
Creation of realistic water simulation rajnishv Vizard 1 09-28-2016 12:25 PM
Regarding World Viz's Unity & Unreal Plugin Support rajnishv Precision Position Tracker (PPT) 6 09-15-2016 06:04 AM
Realistic gaze behavior of CCHD characters Frank Verberne Vizard 4 11-06-2013 12:07 AM
Compatibility with Unity Software file extensions Uttama_vizard Vizard 0 01-19-2011 12:10 PM
