You are right, I rewrote it so that I use the Grabber and that solved it!
I didn't use it from the start, as the experience was a bit limiting with larger objects due to measuring the distance to the objects center when grabbing. But in this thread you provided a solution for this and now it works well! Would be great if setting bounding box vs. object center would be an argument in the standard grabber tool! Thanks! |
| winviz.exe has stopped working | TarkaDahl | Vizard | 2 | 05-21-2012 03:06 AM |
| Winviz.exe does not "finish". (Pylab problem) | migoloco | Vizard | 1 | 09-23-2010 12:42 PM |
| winviz.exe problem | llqqff | Vizard | 2 | 07-16-2010 10:08 AM |
| Extending python using winviz.exe | Enlil | Vizard | 1 | 08-12-2009 11:59 AM |
| trouble with winviz.exe | bnord | Vizard | 4 | 09-21-2006 05:22 AM |
