Old 08-28-2016, 02:11 AM
I ran both of the following scripts with the attached model and it worked. Only the alpha of one sub-part was changed. Does it only happen when you parent the object to your factory model?
Here is the object loaded on it's own:
object = viz.addChild('oil_pump.osgb')
object.hint(viz.COPY_SHARED_MATERIAL_HINT)
object.alpha(0, 'OilDrop1')
Here is the object parented to the ground model:
ground = viz.addChild('ground.osgb')
object.setParent(ground)
Issue Getting Quad Buffer Working nabrahamson Vizard 2 08-30-2012 09:43 AM
win32ui winviz.exe has stopped working TarkaDahl Vizard 3 08-10-2010 05:19 PM
ppt 3/4 working sisun1030 Precision Position Tracker (PPT) 6 03-05-2010 09:11 AM
Flock of Birds (Only Position Tracking working? No Orientation?) TheLostBrain Vizard 6 05-10-2008 08:39 AM
Collision with avatars and scene not working JvdBosch Vizard 12 09-14-2006 06:01 PM
