Old 12-03-2015, 04:08 PM
pitbool pitbool is offline
multitex fragment shader issue for different sized textures
I am trying to blend an algae texture to a sea floor texture. The algae texture file is a 512x512 jpg image. I am retrieving the other texture from our ocean osgb model. This texture is a 1024x1024 baked into the model.
I have tried four ways (see below), but unfortunately, none works!
All are shaders, except for the first.
1. Using texblend - this gives some kind of blending, but it is non-uniform and not upto our expectations.
2. Using the texBlendFP.frag shader - the first texture do not show up at all.
3. Using the custom blend shader from \examples\shader\tutorial_multiTexture.py - the first texture do not show up at all.
4. Using the code from multiTexture.py (Tutorial: Multi-texturing) - strangely, same result as in option 1 above!
I have attached the py file in txt format here.
Any suggestions on how to get this to work?
Thank you!
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
