Old 11-04-2015, 06:55 AM
mape2k mape2k is offline
The script updates every frame: if the framerate drops below 30fps, the recording rate will also suffer.
You can decouple this by using the viz.director to start the data recording in a whole new thread, but it will be time asynchronous from the main thread so be careful.
Cheers!
Vsync prevents using fresh motion capture data in physics simulations? performlabrit Vizard 2 11-05-2013 10:48 AM
Physics engine update rate and display rate zharuViz Vizard 12 10-28-2013 06:52 AM
Frame rate issue kopper Vizard 2 06-09-2013 10:53 AM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
record and playback head-tracked data michaelrepucci Vizard 3 11-25-2008 04:20 PM
