Old 11-01-2015, 06:16 PM
Vaquero Vaquero is offline
Question Cal3d & predefined LOD?!
In a post dating back to 2007, someone states that LOD (Level of Detail) is "currently" not supported for Cal3d avatars. It is now 2015 and my question is simple: Are levels of detail supported for avatars in Vizard 5?
If yes: how do I set it up? I want to use the handmade meshes for the levels, not some poly-reduction algorithm at runtime that messes with the mesh.
If not: This is so essential for performance. If I want to populate a scene with some high quality avatars for realism's sake, I need a way to swap the highpoly meshes against lowpoly meshes for obvious performance reasons (the same goes for the shaders in use on each resolution). I can't make a set of low poly and a highpoly avatars and confine them to inner & outer bounds, if a person should be able to move freely through the crowd.
avatar, cal3d, lod
Error using CMF export from 3ds max to cal3d in some avatars disbeat Vizard 4 04-16-2014 12:40 AM
Cal3D Normal handeling sleiN13 Vizard 0 06-28-2012 04:07 AM
Vista, Cal3d, Max 2008 shivanangel Vizard 6 09-25-2008 03:26 PM
Incampatible CAL3D files luakt Vizard 4 09-15-2008 12:28 AM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 05:48 PM
