Old 06-07-2015, 04:46 PM
tokola tokola is offline
Red face Custom-permanent tooltip
I am trying to create a permanent tooltip using panels, but cannot make it work as desired. I basically want the panel/tooltip to be linked to an object (node) on screen, using normalized window coordinates. The problems are:
1. Using tooltips I get limited functionality/appearance and cannot seem to be able to translate to window coordinates (0-1). I couldn't find a way to convert the normalized coordinates in a window to pixels in the window (not world).
2. Using vizdlg panels I can format the panel as desired, but cannot link it to the object (a shape primitive). The offset does not work as expected although the object is added as a parent to the screen (not the world). Additionally, the panel does not follow the movement of the object, as would be expected from the linking.
I attach a script with my experiments. Both approaches can be seen and tested.
Help would be greatly appreciated!
links, normalizedtopixels, tooltips
Adding custom faces mjabon Vizard 2 04-01-2009 08:34 PM
How do I add custom functions to a custom plugin? reedev Plug-in development 7 02-01-2009 03:39 AM
Custom Drop-Down Menus and Sliders south_bank Vizard 2 05-20-2008 04:27 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
