Hi Jeff,
Thanks for your help. Unfortunately this did not do the trick. I downloaded the installer and copied it into the Scripts folder (the same as pip-script.py) and ran Vizard as an administrator but still not luck. Here is my error message when I type "install numpy‑1.9.2+mkl‑cp27‑none‑win_amd64.whl" into the Run Arguments toolbar and run pip-script.py: Code:
** Loading pip-script.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective': missing __init__.py
file, filename, etc = imp.find_module(subname, path)
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective\recipe': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'c:\program files\worldviz\vizard5\bin\lib\site-packages\collective': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\zc': missing __init__.py
Requirement u'numpy\u20111.9.2+mkl\u2011cp27\u2011none\u2011win_amd64.whl' looks like a filename, but the file does not exist
Exception:
File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\basecommand.py", line 122, in main
status = self.run(options, args)
File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\commands\install.py", line 257, in run
InstallRequirement.from_line(name, None))
File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\req.py", line 151, in from_line
link = Link(path_to_url(name))
File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\download.py", line 323, in path_to_url
url = '/'.join([urllib.quote(part) for part in filepath])
File "C:\Program Files\WorldViz\Vizard5\bin\lib\urllib.py", line 1282, in quote
return ''.join(map(quoter, s))
KeyError: u'\u2011'
Storing debug log for failure in C:\Users\mkinated\pip\pip.log
https://drive.google.com/file/d/0B5d...ew?usp=sharing Any idea what went wrong? Last edited by makinate; 05-28-2015 at 08:09 AM. |
| External package problem from Vizard Package Manager | pwsnow | Vizard | 1 | 06-13-2014 09:11 AM |
