Old 05-15-2015, 02:44 PM
As a first step, make sure the tracking is set up optimally and you've done everything possible to improve it. Also, make sure the Oculus LEDs are not getting power as they may interfere with tracking the Phasespace LEDs.
Swapping markers might be difficult to get a good result with. If you have a way to determine which tracker is getting reliable data then you could re-parent the viewpoint to that tracker in the main script. See the following example:
http://forum.worldviz.com/showthread.php?t=5260
You would also need to apply an offset to the left/right trackers to match the location of the front tracker.
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Multiple views with robot: collision & scaling problems tokola Vizard 4 01-28-2013 09:59 AM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 08:26 AM
3d viewpoint movement spacefarer Vizard 9 07-25-2006 03:37 PM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 02:10 PM
