Old 03-13-2015, 01:48 PM
lklab lklab is offline
The problem with using multiple post process effects is solved somewhat. It's possible to use the blend effect to use two post-process effects at once with the oculus and to turn off and turn on effects simultaneously to make it appear as if an additional effect is turning on.
The problem I have now is that the blendmask effect does not cause the mask to appear in the same place in each eye for the oculus. Is there a way of doing this that does not involve using the HorizontalSplit effect and doing trial and error with slightly shifted masks until they lineup?
from viz import *
import oculus
import vizfx.postprocess
from vizfx.postprocess.color import BrightnessEffect
from vizfx.postprocess.composite import BlendMaskEffect
ground = viz.addChild('piazza.osgb')
#set up oculus rift
hmd = oculus.Rift()
sensor = hmd.getSensor()
viz.link(hmd.getSensor(), viz.MainView)
viz.setMultiSample(8)
viz.go(viz.FULLSCREEN)
flash = BrightnessEffect(brightness = .8)
dlmask = viz.addTexture('dlblendmask.jpg')
dlstimeffect = BlendMaskEffect(dlmask,black=flash)
vizfx.postprocess.addEffect(dlstimeffect)
oculus, post-process, vizard 4, vizfx, window
Oculus Rift Drift teklab Vizard 20 04-01-2016 07:57 AM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Oculus Rift connection problem mshukun Vizard 1 10-01-2014 12:15 PM
Oculus Rift Fullscreen teklab Vizard 6 05-21-2014 06:11 AM
oculus rift and inertia cube interaction problems apboone Vizard 4 03-13-2014 10:45 AM
